- Mar 13, 2005
- Raleigh, NC
Well we made it to Hatteras.
And we decided to recreate a photo from years back
112 mph is pretty good.
I think those are inflated numbers112 mph is pretty good.![]()
Group Camp , UREI saw you post this on FB and meant to ask. Where was that?
I thought that looked like the group camp.Group Camp , URE
I had to look up genturi. I assume that is to get the exhaust up and away from the bus?
correctI had to look up genturi. I assume that is to get the exhaust up and away from the bus?
You’re parked in the exact same spot I was for the get together! Hope you had a good time.
I did raise the tag to get all the weight onto the main drive axle and it still did not helpI swapped an air locking diff and axle shaft into one of my trucks with I imagine a similar sized diff for around $1500 all in, definitely needed if you drive on anything other than packed gravel or concrete. Especially since you have that non driven tag axle screwing you even more.
Agreed, we used to have some flatbeds that did all right with a load, but were useless empty. A few of them had diff locks, made all the difference in the world.I swapped an air locking diff and axle shaft into one of my trucks with I imagine a similar sized diff for around $1500 all in, definitely needed if you drive on anything other than packed gravel or concrete. Especially since you have that non driven tag axle screwing you even more.
