Jeepnmud74
New Member
- Jul 14, 2005
- Mount Holly, NC
OK bro heres the deal. I run the superior super 35 kit. I have not broken anything in my axle since I put it in. Before I put it in I did bust a ring and pinion which was the reason for me putting the super 35 in it. Had I been better informed before hand I would have swapped in a different axle. The beefed up 35's will work fine under medium wheeling and 33" to 35" tires but when you get into the larger heavier tires the axle tubes will bend and mess some stuff up. Unless you have it trussed. I am done putting money into my 35 and am building an axle to swap into mine now. There is a jeep only web site out there that has pretty good info on it. If you are planning on building your Jeep join that forum also. You may be able to find some helpful info there.
jeeps-offroad.com
jeeps-offroad.com
