obullfish
Carolina Trail Blazers
- Nov 21, 2011
- Candler N.C.
I'd name it the Cock Gobler.My new moto is going to be "upgrade as it breaks". lol
EDIT: picked out new paint job scheme. @McCracken can you think of a good hood phrase lmao
I installed one of them in my old TJ about 9-10 years ago and it's still going strong. Don't remember what the hardware was at that point though.I get that some vendors will always be more expensive than another. That's life and the way business works.
For the amount of R&D Novak has done and made freely available. It is justifiable their prices. However. Was not to impressed with the Allen head bolts, the non locking heim joint nuts and the fact there is metal on metal shifting here. Would have hoped for at least some teflon washers as opposed to SS washers.
So going to update this shifter assembly with some better hardware and get it installed
Front driveshaft > hard top.
That's the wrong seal for the transfer case input shaft.
The seal retention spring should not be visible from the outside
So I put the seal on backwards you're saying?
I don't think so. It looks to be the wrong seal all together.
Many times the rebuild kits come with a multitude of seals that may have the correct dimensions, but aren't the actual correct ones.
Yours should have a flat front face and an open back side where the spring goes.
