- Mar 13, 2005
- Raleigh, NC
shows the axle side heim on drag link and it moves a lot so I guess I need to take that slop out??
What do you mean "slop"? Aren't those brands new heims?
I mean the play/motion that the heim joints allow..it seems that the drag link axle side shouldn't have all that flex in it so was thinking take out the misalignment spacers so it can only move drag link up and down with flex but not allow it side to side movement..hope I made sense now sorryWhat do you mean "slop"? Aren't those brands new heims?
Ok so I know u won't believe me BUT high steer arm will not clear the leafs so drag link would still be some weird contraption. I've looked into it..measured and studied it..it would sit way below leafs unless I used like a 2"+riser/spacer..even thought to drill it and bolt/weld factory one on pass side but same thing, too low. A high steer arm would have to turn up a good bit.Or just install a high steer arm like we've told you for weeks now.
The bo
That does not make sense. If the heim can move side to side, the holes in the arm are too big, and/or the bolt isn't tight enough, or you damaged the heim (maybe cooked or knocked the nylons out of them).
No no..I'm sorry, I mean the side to side movement that the heim joint allows for flex like its supposed to. Heim is fine, bolt is tight no play in the steering anywhere. But because the heim can flex up and down and flex side to side it seems the side to side flex should be taken away?..I hope that makes senseThat does not make sense. If the heim can move side to side, the holes in the arm are too big, and/or the bolt isn't tight enough, or you damaged the heim (maybe cooked or knocked the nylons out of them).
As soon as I find 8" coil springs (get $ to buy em) I'm going 4link and be done with this nonsense lol..I tried but oh well.You sure did complicate the shit out of that front suspension. Seems that a stick radius arm setup would have been easier than that
That just means the steering is designed poorly. All links and joints should be laid out so that the forces only act in the manner for which they are designed.No no..I'm sorry, I mean the side to side movement that the heim joint allows for flex like its supposed to. Heim is fine, bolt is tight no play in the steering anywhere. But because the heim can flex up and down and flex side to side it seems the side to side flex should be taken away?..I hope that makes sense
And your probably 100% right...unfortunately lolThat just means the steering is designed poorly.
Or maybe just fucking save for a Dana 60 and only fuck with the suspension once and be done. It's cheaper that way, just ask all the guys who are now on tons that used to have a Dana 44.As soon as I find 8" coil springs (get $ to buy em) I'm going 4link and be done with this nonsense lol..I tried but oh well.
Once we move and settle in, ill hope to get some coil springs and redo the whole front, which the D60 down the rd will be 4link anyways..getting a coil bucket on pass side will be little tricky
BUT...BUT..lol I've come this far,, this d44 will get used at least once and before its all over it will get fully abused to its limit before it gets removed..I mean its pretty close. Jeep is ready once I "tweak" the steering and track bar properly or little bit better lol..Or maybe just fucking save for a Dana 60 and only fuck with the suspension once and be done. It's cheaper that way, just ask all the guys who ate now on tons that used to have a Dana 44.
They don't countWhat about the guys that used to have Dana 60s, but now have Dana 44s?
Haha but with no leafs in the way I can at least have proper steering geometry even without high steer armsAnd you're going to fix it by building a 4-link, because leaf springs were too complicated.
Makes all the sense in the world
The extreme flexibility of a good 4 link will cause a whole new set of steering geometry problems. I'll bet most of the guys running 4 link use hydro steering to eliminate this problem.Haha but with no leafs in the way I can at least have proper steering geometry even without high steer arms
Yeah but I'm used to that ...my yellow one steered flawlesslyThe extreme flexibility of a good 4 link will cause a whole new set of steering geometry problems. I'll bet most of the guys running 4 link use hydro steering to eliminate this problem.
NotedThey don't count
Noted![]()
