Jeff B
Thanos was right
- Dec 23, 2006
- Lincolnton N.C.
Full hydro is simple. Just mount thew ram and hook your power steering hoses to it. Viola! power steering!
This is definitely the route I'm gonna save for!Full hydro is simple. Just mount thew ram and hook your power steering hoses to it. Viola! power steering!
stupid lies associate I mean Lowes associate.Well we will discuss all that once I start gathering all the parts!You might need a 'orbital valve with return to center' but I think there's a way around it, kinda like how you can wire a 3 wire well pump to use two wires without a control box.stupid lies associate I mean Lowes associate.
Since double sided rams are pretty much same price, is it not worth going full hydro steer
Two trailer park girls go round the outside, round the outside...What's an orbital, does it circle the jeep? Then go to the center?
Well the update is........uhhhh....need a trailer to take it out and test it out a little...or a lot lol. We moved, settled in and haven't touched it. It just needs a test run to see how it does and go from there....
Figured steering play will work if I just unlock drivers side hub while driving around and lock it in once lined up the trail (slow crawling turns good but moving any descent speed while locked in and the dead spot play is really noticeable)....
So that's the update lol
The most well put together response I have ever read by JF. Someone frame this![]()
Pretty much..Newton ncSo you are in Hickory now?
Where in Newton are you?Pretty much..Newton nc
Right next to Robinson building supplyWhere in Newton are you?
10-4. Im sure you have checked them out but they are a good resource for building materials.Right next to Robinson building supply
Haven't yet but will soon to build sliding garage door and tracks. Good to know ur local, will definitely keep in mind when I could use a hand or advise since you're local10-4. Im sure you have checked them out but they are a good resource for building materials.
There are a number of us in the area if you need any assistance.
Thanks bud
