Scooter402
Ruffling feathers and shaking trees
- Feb 4, 2009
- Livin in an Amish Paradise
Got it. I've had good luck with CV shafts in mine, too.Yeah I've got the CV yoke. I'm not concerned about driveshaft at all, I've always done really good with pinion angles and driveshafts!
I'm just a little concerned about that positive caster that's all
Well...I see one of a few options here, since you don't have link mounts welded on yet. It looks like your spring buckets are tilted forward a bit. You can either tilt them back such that they are in line with your bump stops, and that might bring your caster up to about 0 degrees, or just a hair back. Some people might not give half a rat's keister about having positive caster on a trail rig, but the steering input/feel may be important to you, so that's your call. I've cut and turned the inner c's on a D44, and it takes a while to grind the factory weld out. And once you think you've got it all and start wailing on the c with a hammer, you'll find quickly that you missed a spot.
It just looks to me that the pinion is pointed awfully high.
