paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
there should be enough local dirt circle tracks that would let ya come run on friday nites or such.... no jumps but fast and door banging.
That's been my thought all along. Would have been great for ECORS as well. Basically like TORC did at the Charlotte dirt track.there should be enough local dirt circle tracks that would let ya come run on friday nites or such.... no jumps but fast and door banging.
If the rules limit you to the stock 7.5 rear end (which I believe they do), then you're limited to no lower than 4.56s.
If the rules limit you to the stock 7.5 rear end (which I believe they do), then you're limited No lower than 4:56s
Yea what he said. With a 5 speed and no low range in don't see a 3.55-4.56 being that much different for a relatively flat track. One may run 2-3 gear the other may predominantly run 1-2. To be honest. I expect to see traction being a big enough problem that you'll want to stud the tires before you are ever thinking about wanting a lower gear. Leaf springs, no traction bar, small tires and sprung over. These things will probably be accustom to wheel hop and u joint failures too. Spinning the driveshaft even faster with low gears won't help that at all.I have no idea what the stock ratio was... but I wouldn't be surprised to see anywhere from 3.07 to 4.10. I dunno what the ideal ratio for one would be, without getting out and driving it a little. At a certain point, you're just driving a stick shift, so as long as you have a low enough gear to get decent RPMS in the slowest corner on the track, it really doesn't matter.
I respectfully disagree about the brakes. There is nothing like using the rear brakes to help start a rotation.
Down shift during that initial rotation followed closely by throttle response, whether a braap or foot to the floor.The more choices/tools you have on how to steer the truck, as a driver, the better
