Chris_Keziah
Joe Dirt @ Rev Limit Fab
- Dec 1, 2010
- Winston-Salem
Personally I'd build a flat belly with where the tcase is currently, no sense in clocking it more. Smooth bellys are more important than belly height.
As far as more bracing the problem I had was making only some parts of the frame stiff and it causing it to fracture. The stock C channel doesn't take not twisting very well.
Soo thoughts/opinions on those trick tabs for mounting the skid plate? I’ve been trying to find some saddle nuts with not really any luck. Really the frame work should support impacts but just need something to attach the skid to it.
What about welding nuts inside the vertical tubes?
I wouldn’t use the trick tabs for skid plate especially if your skid plate is plastic. It may be OK if you skid is 1/4” plate...
why couldn’t you use 1/4” thick tabs? Either tap the holes for your bolts or weld some nuts to them.
Use a threaded rod adapter for the front 2. Or a stud with a nut welded on in the center.
Let me know how you like that drunk fb purchase, I've seen those and thought about adding them to the tool box for the notches that are kin to Karens.
