Rich
Asshole at large
- Mar 17, 2005
- Central PA
To the mockup phase, to see if any of my "calculations" will actually work out in reality.. the short answer is pretty much yes! The axles are sitting 1/2" higher than they will at trail pressure, and the frame is set at full suspension compression. Should work out to 4.5-5" of compression while keeping 25" belly clearance at ride height.
42's at 5psi-- 13" under the lowest part of the axle which is only a few inches wide..
Front- Yeah, that crossmember has GOT to go, along with a little bit of the frame rails. The towers for the upper links and the chunk are going to be a TIGHT squeeze inside the frame.
Rear- Shouldn't be too big of a deal, though much of the frame visible here is a goner. Won't have a ton of steering angle unless I get more creative with the tube work.. Driveshaft angle is AWESOME. I reallly love the toploaders because of this. At full compression, the driveshaft has about a 0° coming out of the t-case.
Looks like the wheelbase will end up at 114-115".
