CasterTroy
Faster'N You
- Mar 21, 2005
- Wallburg
[mention]77GreenMachine [/mention] [mention]BigClay [/mention]
And who helped fix that???@Stuntman Autoworks was already brokenwhen I broke a 5/8 grade 8 upper link bolt on top of Atomic Ridge in Windrock last summer.
Anything CAN break. Unless you drive like a pansy, @CasterTroy.
Seriously. I mean, I baby the thing everywhere I take it.Holy frame crack man
I can’t wait for the ripple effect of how much harder you can push it now.
That was just a passing idea, but when I/we talked about it more, it won't happen.Nice !
I wouldn't build a skid out of AL. It galls up badly when skipping over rocks.
I'm all for AR / Hardox type material. Glides like butter.
I have really became a fan of 1/2 HDPE over 1/8” mild steel.
Commercial restaurant supply houses are a good source. Aside from places like CL and FB marketplace of course.Where is the best place to source this?
https://www.triadplastic.com/Where is the best place to source this?
I really don't have much to add of value here bc I'm still playing JV ball and yall in the bigs; however, every time I see sticky treps now I start salivating!This has been the easiest series of upgrades yet. Pay MarsFab, wait for pretty pictures
The main objective is to push the front end forward enough to clear the oil pan. This required all new panhard (I'm Mr Fancypants now) and mount, 3 link tower, truss re-work and links. Chris was able to push it 8.5" forward and still maintain some "Ranger-esque" aesthetics up front.
While cleaning the frame, he found the frame was fubar, bigly, at the track bar mount. This would have been a gigantic issue on the trail.
I love how he relocated the airshocks behind the axle as new frame end mounts and associated engine bay mods would have been a huge undertaking.
View attachment 327711 View attachment 327712 View attachment 327713 View attachment 327714 View attachment 327715
every time I see sticky treps now I start salivating!![]()
Use less tire shine and it won't run down on the tread.Same.
I USE to think Jody had talent. I USE to have envy for said talent. Now I realize, it truly was JUST tires![]()
Dude THAT's my technique doe...jack stands, 4-lo, spray the outside wall, inside wall AND the lugsUse less tire shine and it won't run down on the tread.![]()
You will love the Holley it is super easy to use and the auto tune can not be beat, it will be super close just off the auto tune it will be a different machine. Did you get the small display or the big racer style? Updating it to the bigger displacement is super easy to so more cubes= Easier frame busting!Well, since you kinda brought THAT aspect up...
I also ordered Holley Terminator EFI that is highly tunable. I recently realized my ECM is bad. Hasn't been playing friendly with the timing tables as well as continued MAF issues. Probably been leaving a ton of power/driveability on the table. With the Holley setup, I will be able to fine tune many things and expect a lot more woopow to be available.
Also, the pistons, heads and upper intake will all fit nicely on the 393 Windsor that is in the works too.
I disagree with that. My Holley was way off on the tune and it felt like I had a different engine after I got it professionally tuned.
It did crank on the first try and worked ok for the time being but the before/after a tune was night and day.
