CasterTroy
Faster'N You
- Mar 21, 2005
- Wallburg
Did you do any sort of cost analysis vs conventional stick? Very curious to know how your numbers worked out.
Yes. I had 3 builders price it stick. They were all within a few dollars per square foot of one another with stick/siding construction:
$130-$145 for heated areas (apartment grade finishes)
$35-$45 for workshop (uninsulated 12 ft sides)
$15 for lean-to
Then I had one of the builders price it post and frame, along with carolina post and frame and Morton. The custom builder was less than carolina, and Morton was nearly the same as stick built. But with Morton you have 3 levels of their product. Their pricing was for the base model. I can't imagine what the "bells and whistles" pricing looked like.
Carolina Post and Frame said:........$90 a sq ft for heated areas, $25 a sq ft for workshop areas, $10 a sq ft for leantos or extended gable canopy areas, $25 a sq ft for finished porch areas. This includes turnkey work. Concrete the whole works. Fixtures included in the heated area along with all painting and flooring. This should give you an idea.......
Also priced red iron, but my site wasn't conducive to square. I corresponded with 2 different outfits that people used on here, but I deleted that folder after speaking to both and them basically telling me that with my size constraints I would have better luck with post and frame. So I can't even remember those numbers
Didn't even consider a mexican carport style building.
These are all graded, slab-ready quotes.
