MetalCraftSolved
- Jun 20, 2010
- NC
Put a bushing in the center so you don't break the trans case.
How is the motor mounted? Whether it's hard or soft mounted, I would do the same in both places.
why? It has a plate under tranny with 4 bolts going into bottom of tranny and that plate is attached to the tube. with each side having a bushing.
do you think the bushings will be to stiff?
I plan to change out motor mounts to stiffer ones also.
Picture your frame twisting. With your current setup, It will try and twist your engine/tranny/transfer case. The transmission case is almost always the weak link and cracks. I've seen this numerous times. A single standard style transmission mount is needed underneath the rear of the tranny.
I can see a XJ twisting, but a boxed YJ frame with all the added steel welded in and bracing I just dont see where it cause an issue
This. Plus the difference in eccentric spacing between the motor mounts and the trans mount. If there's differential movement there, the transmission gets caught in the middle.
You get the seals cut for 35 spline? Double them up? If not grease them up good and call me when they wear out. I made a little jig to cut them out bigger for 35 spline and 40 spline axles so there's not so much tension around the shaft.I bought Seal it seals from speeday and got them in, I added rtv to be safe
Very cool! He gonna get to drive it when it's done?
Couple of those links look familiar. . They fit?
