- Mar 20, 2005
- Morganton NC
Only down side to the deck over is all your weight is higher. The lower your deck is, the better control you will have, especially when towing with a lighter lighter tow rig.
Also agree with Rob about the flip-up ramps, nice to have to see the trailer when it is empty. I hate my side slide in ramps and don't use them unless absolutely necessary. This winter I'll probably make them flip up. ......
HTH,
Shannon
The hitch i got already has a hole in it for a jack. So I got the 5000 lb jack because that was the biggest they had.
So i do i need to return it and get a bigger drop leg? 10000 lbs?
How do they mount? Can i just weld it to the cross piece on the tongue?
The one in the front will be a crank style jack.
Would yall suggest the two in the rear be a pinned foot or a crank jack?
I am going to return the hitch I have now for one that can be adjusted. I have seen hitches that have four bolts going through a plate with an upper and lower set of holes.
WhyThe straight axles are getting replaced with 4" drop.
Why
Most builders use 6" C with the same axles you have now.
When you use drops it will change the spring placement from the ones I looked at.
What reason for turning your 6" C to the outside?
Jon
