braxton357
Robot
- Apr 6, 2005
- Morganton
More like 7500 lb.
where are you getting that info from...I'm showing 49-5400More like 7500 lb.
ten for, I'll look em upThis has been covered in several other threads numerous times Marty
You want around 100lbs split between upper and lower spring rates. Not a firm rule.
LMBO.. I was already thinking He's either, the one that customer told me had it before him or he was going to do the work...one of the two i figured since he jumped in so early on trashtalkMaybe from him previously owning it?
More like 7500 lb.
ok I'm really not being difficult but I'm not seeing this unless there's some magical weight added to this truck that I haven't seen yet lol, so far looks like a normal stock ext cab dodge...7800, and not a penny less.
Would ORI struts work on such a heavy beast?
what website/fact sheet are you guys going by to get those weight numbers. That majorly changes my numbers on spring rates calculations and such
Ok sorry, was looking at factory specsOnly way that truck would weigh anything close to 5400 is it was a reg cab short bed 2wd. Most 4wd diesel trucks are gonna weigh anywhere from 7-9k.
Dang dude chill, you act like doing an axle swap and some coilovers on a basic radius arm setup is rocket science or something. You seem upset that I'm building your project...get over it. Setting up the coilovers is the most technical part of all this..rest is nothing new to me. I've done 5 1ton rigs now on sheet metal unibody so building on a real frame is an upgrade lol. Either way, cool your jets dudeI've weighed the fuckin thing, several times. Also it's a 2nd gen.
couldn't agree more, I don't trust any "paint" that's supposed to be "weldable" to not, even the slightest way, effect the structural integrity of a Mig weld especially. I will be coating the axle with that stuff per customer request/demand but will still wire wheel areas to be welded, especially where I'm widening the axle for sureAll that hype for a field repairable coating don't sit with this welder operator.
I get the idea but don't trust the purity of the selling point.
am I missing something
I'm actually looking forward to this custom build. I've been dying to put my fab skills to the test on a real thought out build and this is def it!
My 99 2500 4x4 5spd cummins quad cab shortbed weighed 7300 on the scales.7800, and not a penny less.
Why are you widening an axle for this project? There are literally millions of trucks that came with an axle made to go under this truck specifically.couldn't agree more, I don't trust any "paint" that's supposed to be "weldable" to not, even the slightest way, effect the structural integrity of a Mig weld especially. I will be coating the axle with that stuff per customer request/demand but will still wire wheel areas to be welded, especially where I'm widening the axle for sure
Not my route but his. He had his plans, bought parts wants to make it happen. I stated my opinion but let the customer get what they desire if they got the funds for it.Why are you widening an axle for this project? There are literally millions of trucks that came with an axle made to go under this truck specifically.
