rockcity
everyday is a chance to get better
- Apr 10, 2005
- Greenville, NC
@Ron is a Ford purist and he stands up when he pees
So then, how’s that pee pal thing work out? I have a cousin that was thinking of getting one.
Fwiw this engine specs out slightly higher than an ls7.
Less than half the price. Lighter and smaller.
It's a beast on paper...I'll let you know "soon" how it is on pavement.
No shit, that’s pretty good. North of 500hp and lighter than an aluminum block and heads fully dressed 400lbs, that’s Pretty stout. But does it drop valves as good? LS7s are known for it.
You made me go double check, myself.
According to what I had the ls7 is 470lbs. And I am actually heavier, 496 dressed. Of course thats a spec sheet number against a car scale number, but in either case probably not enough delta to matter.
Kinda moot point anyway, ls7 wouldn't fit between the shock towers
I've got nothing against bowties...my k5sare Chevy powered my Ford's are Ford powered.
Bought a new one...
I'm glad somebody bought this so I didn't feel like I needed to. Congrats!
What's binding?Cracked a rear shock and kill another set of rear sway bar links at AOP.
Shock hit the coil bucket and cracked the shock body. Sway bar hangs down to low and I keep hitting them on rocks.What's binding?
You’re just ruff on shit.Cracked a rear shock and kill another set of rear sway bar links at AOP.
The ones on my Jeep currently are about an inch shorter. When they come off you can have them.Cracked a rear shock and kill another set of rear sway bar links at AOP.
Well he did follow Chris, Phillip and myself at AOP. [emoji41]You’re just ruff on shit.
I'll add a picture later.
No they aren't trimmed at all. Guess I need to do that.These should be able to come off sometime in the next week or so.
@ncsutj your coil buckets not trimmed back far enough?
Nah, just notch the frame and outboard those bitches.No they aren't trimmed at all. Guess I need to do that.
Why the hell did you go and do that?Sold
Well, not today, but last week I finally dug it out of the woods at my buddies house. It's at the shop now getting tires rotated and balanced and an alignment. After sitting for over two years it fired right up and ran. Still got an engine knock and a bad spartan locker but it's a start. I'll be happy just to get it back on the road.
Front pads and rotors on the DD (rears done last weekend) and finally installed my new (to me) Warn 9.5cti. Also got the hood and hood latch put on that @Nakoma hooked me up with after the mishap I had last fall at URE. Oh, and smoked a pork shoulder all day for dinner...
Sent from my SM-G950U using Tapatalk
