X-jeeper
- Oct 29, 2006
- Raleigh, NC
suspension and steering especially are not places you want to cobble some shit together.
yeah i figured that wouldn't work too well...its just a temp to drive it around here and see if i like it. now that i have driven it some around the back roads and messed around the yard...they have to be redone anyways cause i can't turn very far at all with those thorn-lugs lol so now on to drawing board for how to make some arms that bend inward about 3" so my tires will clear..anyone got pictures of curved control arms they've done or seen.That upper link tied to the top of the diff does not look very beefy. My buddy ripped his aftermarket link mount off and it caused all kinds of damage. Might want to rethink that design...
I'm well aware of my stock axles, welded front and rear, big nobby ass tires and the most important of all...very very light foot on the skinny!! i've done the same setup on 39.5s and no issues but again i'm very light footed and just like to get out and enjoy the trails just as much as the next guy. I work with what i can. This is also why i'm so big on Grooving Tires like these and Deflating...these 2 along with easy foot has gotten me all the fun i desire for now anyways..until someday i can get some real axles.please tell me this is an April fools!!?? If not
let me know when you are guna wheel that thing!....I will ride behind you and pick up parts as they come off! LolJK
Seriously, you may want to revisit this..
lol are we placing our bets already he he. nah, no drama here. i wouldn't post my stuff or my new jeep if i was worried about peoples comments anymore..i don't care anymore. I'm proud of my jeeps just as much as anyone else is proud of their builds. Only difference with me and others seems to be lack of finances. If i had the funds for heim joints, the proper steel tubing/dom, proper rims, bigger axles and some better tools (plasma cutter/torch)..my builds would be descently comparable to others but most of the time i'm working with scrap metal, used control arms, and just use what i can to make them work and it does but i'm also not trying to build/claim to build some buggy rock-crawler or badass jeep. It is built to fit my needs and budget!!In before the drama starts...![]()
but the joints still have to allign in a straight line right? so do i get the metal shop to bend some dom but leave like 2" straight on each endPicture a straight piece of tube, only curved.
i have enough money for that lol
hey what's wrong with my Thronbirds? i admit they suck in their stock form but these things are far from that lol. i would actually prefer this set of tires i've done over tsl just cause the lugs can be cut to be deeper and longer than tsl.well he does have thornbirds, so I wouldn't put anything past him
and for the upper arm do i just sleeve them with the dom, then tie them into the lowers with some x-bracing half way upTube can be curved is you can notch tube so the bushings/joints/whatever align properly
ohh i'm def listening and trying to learn better. thanks. and yeah they do dig which for me and little axles could be a bad thing lol. but with locked front and rear and running at 0 psi i crawled right up couple banks around the yard no problem so they work good. it's funny....at 0psi they have no bulge and still pretty stiff for being 0. i let all the air out of them just for test and then i could finally see bulge but nowhere near flat. that 4ply sidewall sure is strong and stiffListen to Jody's advice. He isn't screwing with you.
The cut Thornbirds look like they will dig. I'd run them.
point takenWhy do you need more flex when you have limited room for up travel?
Think about it. That's not juice for the squeeze...
ok i feel stupid but you lost me...my add must be kicking in(why i never went to school and learn everything hand on lol)Turn the joints 90* from now they are pictured.
The bolt holes would need to be in the same plane as the bend. Meaning the bend would go towards the engine side as would the attaching bolts for the links.
