Toyota Monster Truck
Here are my H1 D-rings installed. 2 on the front and 2 on the rear of the truck...
Took the seats back out so I can cut down the brackets. I want to lower the seats approx 2 inches. Also installed my twin sticks. I had to cut a portion of the floor out to get everything to fit. I am going to build up a semi-center console type set up which will cover the large hole in the floor board... I also still need to figure out where to mount the shifter for the C-6 Trans.
Took 2 inches from the seat post legs. Should be the right height now. Readyfor powder coat...
Lastly, I installed the B&M Trans Shifter
Not much done here lately. Dialed in the shocks some. Lowered the ride height by 2.5 inches. It is still tall but any lower and I may rip a fender off at full articulation
Any updates? Been following it since the beginning. What did you use for the center console
Sorry for the very late response. I have been super busy on some other projects. The truck is sitting in my garage, I have not worked on it in over a year now. I am planning to start working on it again soon. I need to run hydraulic lines, break lines, do some wiring and a few other odds and ends. Stuff I am really not good at. The welding and bolting things together was the easy part I guess... I will update this thread once I get started again. George
