drkelly
Dipstick who put two vehicles on jack stands
- Mar 21, 2005
- Oak Ridge/Stokesdale, NC
I agree. But hate to break it to ppl that think they have a 3500lb 1 ton jeep, they're likely off by a half ton.
or even more.
I still think the 99-04 superduty axles are the way to go for now. Yes you can get factory 1550 shafts for the 05-up axles, but with good joints (300m) 1480's are not the week link at 35 splines. Your still dealing with stock axle material. After market axle shafts for the 05-up axle's are hard to find and expensive. ECGS has there lifetime shaft kit with foote stubs for the 99-04 very resonable. I dont see the need for 1550 joints with 35 splines. Maybe 40 or 47 spline, but not 1.5" 35 spline.
I need an 05+ front for my Duramax. I want to do about a 3" lift with radius arms and keep it low on 285s....like this one. Stock front driveshaft, no exhaust mods, stock transfer case, and won't even have to gear it. For what it costs to beef up the front end of a 2500HD, I'd be well over half way to a solid axle setup. Hell, the axle is the cheap part!
Found some cool stuff on pirate. Ford has updated the part numbers for 05-up SD axles. The replacements are 1550 jointed shafts.![]()
FC3Z-3220-B short side
FC3Z-3219-B long side
These are the part numbers. Evidently in 2016 and newer super duties they went with a 1550 joint.
The problem is I don't believe they are an upgrade. I think they would be wasted money. The shaft is going to brake long before the u joint, whether it be 1550 or 1480.
In the same thread on pirate, there are also quite a few people who have broken several of the stub shafts. Some in a jk with a 3.8 and 40's. Yes they are 35 spline, but the material is still sub standard. The best buy for the 05-up axles currently would be the chromo stub shafts from Branik. Running these with stock inners would hold up to alot.
I still think the 99-04 axles are CURRENTLY the best buy. They will get there eventually, but the after market hasn't caught up to the 05-up axles yet. Yes there are aftermarket parts, but not enough to drive the price of these parts down. The 99-04 axles are marginally cheaper, but after market parts are significantly cheaper.
The cheapest chromo stub shafts for the 05-up axles are 250$ each. You can buy chromo 35 spline 99-04 stubs for 150 bucks all day long from a list of venders. (BTW, ECGS said they have there lifetime warrantied shaft kits for this axle also.)
FORD 60 CHROMOLY 35 spline- Outer Stubs Unit bearing Style
On top of that, the 99-04 axle use the same locking hubs or drive flanges the old 60's use. They are cheap to source new or used.
But you have to buy new unit bearings or bore the stock ones to use 35 spline.
For a trail only rig there are cheap ways around that. I know of several guys that bored the unit bearings with a 1-1/2 drill bit on a drill press. Believe it or not it worked.
And me. And most people who think it through.i always want my driveshaft to be the fuseable link I'm my drivetrain , but that's just me.
