braxton357
Robot
- Apr 6, 2005
- Morganton
Who did the block work
Looks like a blind 8 year old negro full of Budweiser.Who did the block work
Shitrock is not allowed in our house so all walls, ceilings will be knotty pine including the finished section of the basement.
How are you going to get an air barrier with no sheetrock and knotty pine panelling (T&G, I assume??)??
Builder says they are going to use tyvek wrap. Said when sealed acts as water and air barrier. I'll have to look into it though...and learn the sealing process.
Gonna install Tyvek on the interior surface of the walls and ceilings, tape all the seams, and apply a self-healing membrane over any place that a nail might poke a hole in it in the future? Seems unlikely.
Yep...it does seem unlikely. Any suggestions about an air barrier for a home like mine are appreciated.
The wall should look more or less like this, interior to exterior:
Interior wall finishes. Gypsum wallboard, taped and mudded. Fiberglass batts with kraft facing. Exterior sheathing, exterior air barrier (Tyvek or similar product), exterior finishes. Exterior drainage plane or air cavity where required.
Don't you live in a yurt?
For the gravel, all you likely need is 12" x 12".
I'm not using gypsum. I'm doing knotty pine tongue and groove. Any suggestions with that kind of interior...?
Why no gypsum? Drywall, paper tape, and mud are inexpensive. The system goes up fast and creates a good air/thermal barrier. All you need is one coat of mud and there is no need to do any sanding, finishing, or painting.
You could use OSB but it is much harder to tape and the tape is more expensive. And it rots faster if it gets wet. And is even more likely to mold because processed wood. AdvanTech or Zip OSB sheathing products are pretty expensive.
I did not know you were a geotechnical engineer with specific information about the subject property....
Big dog, he already said "no shitrock". Pine paneling only. Yall need to get over your uppity high class Cary living attitude.
