ckruzer
Infidel
- Jul 2, 2015
- asheville nc
pulled it out. discovered a front axle leak out the long tube. discovered the prop valve is leaking. guess need to pick up some teflon tape? wired up the speakers and took a test drive to test the brakes after another tweak - stops much better. found the rear lines were pinched shut with the flex tube.
