marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
ok sorry, that's my planned setup.That's not a 3 link
Anyone on thisSo quick question guys. Since I now have a big boy welder (220amp) 230v can I weld a gusset to the cast housing in the pumpkin and the CAD housing which appears to be cast also
That's my planned 3link
Not bashing buddy, just informing you.ok sorry, that's my planned setup.
Preheat, weld and let it cool slowly or it will crack.Anyone on this
So put the torch on it for while, weld, keep torch on it some more than it's good.Preheat, weld and let it cool slowly or it will crack.
On CAD axles, many times it is actually easier go to C to C with a low profile truss over the pumpkin and them tie to cover into the truss.
(Too late to go C's to C's)
231 and 242 for now, I have em both so why not. I will eventually get some gear driven stuff later on but I will make those work.115 seems a big long. I don't thing you'd gain much stability by going longer....you'd just get high centered easier. What t case setup are you going to go with?
I think my wheel base is 110 and it's plenty
And don't ask me how I'm doing it lol, nobody would approve haha
Not quite yet, I'm mounting both back to back till I buy the proper kit later for gear casesAre you just planning on using the planetary gears from the 231 in a crawl box or? If I missed something I apologize.
Yeah I am, got lazy and started on other side.. I'm getting there![]()
If that bottom has a gap in it like it looks like it does. You’ve made a weak place in your playing right where xj tend to bend and crack anyways. You need to add a piece that fallows the contour of that bend and then add a fish plate to make it stronger on bottom and the sides
So you're going to use the front half of a 231 add a spud shaft and 242?
I looked at cutting up a 231 to use it as a doubler so save on money but.....somehow the ways that I try to save money end up costing me the same and wasting a lot time.
With that said, I'm going to buy a custom planetary housing a put 231hd internals in it. This will be mated to a ford 205.
