- Mar 20, 2005
- Hendersonville, NC
Ha..just saw this.
Gear pattern looks decent. You should consult a professional on the next setup.Installed 4.11 gears and a Detroit in the rear 8.25 of my XJ. Added a 30 spline Grizzly and chromoly shafts up front with some used gears for the 30.
Flacid penis shaped bookshelf?Nothing done to it today but a teaser for what's to come.
This is what I get for being a procrastinator. Smh [emoji35] In case I think of being it repaired vs. just selling the ZJ, where's a good place in Asheville that could repair this for not too much $$? If I had a welder/could weld I'd do it myself. If it was a wheeler instead of a DD I'd get frame stiffeners.
Got the upper link mounts tacked in and sat the Jeep down. Need to find 3 ft of 1.75 so i can replace the mock up upper link. Jk coils helped the ride height a lot.
What diameter tube are your rear lowers?
Nice crocs!Hardcore stuff going down at the house this morning. Replaced the broken dipstick on my XJ. Figured it was time to check the oil after driving it for 4 months.
Pro tip: when you forget your external torx sockets at work, Vise Grips become the universal Torx socket.
I almost liked that pic, then I spotted crocs.Hardcore stuff going down at the house this morning. Replaced the broken dipstick on my XJ. Figured it was time to check the oil after driving it for 4 months.
Hater.I almost liked that pic, then I spotted crocs.
View attachment 282756 I took advantage of a little off time last night and today to get my new transmission mocked up for my old beater car. Took out a M21 Muncie and put in a new TKO600 with a scattershield. Trying to decide now whether to remove the old bellhousing motor mounts or just leave them since I am adding a crossmember under the trans.
