drkelly
Dipstick who put two vehicles on jack stands
- Mar 21, 2005
- Oak Ridge/Stokesdale, NC
Good luck @C.Berry !
I would caution you to be reasonable with your expectations. More isnt more. You arent adding 10lbs of muscle mass in 2 months unless you get friendly with a needle.
This. Best case for a natural athlete is about 10-15 lbs after a year of solid training (1 lb of muscle mass per month) assuming you are eating, training and sleeping properly. Then typically half that for the second year, and half of that again for the third year.
If you are trying to build speed and endurance, then the last thing you want is large heavy muscles to carry around.
Regarding pull ups, I have some advice of how I got stronger at doing them:
- The entire body should HANG from the arms, meaning no kicking or movement of the legs to 'help' get moving/up.
- Start from a complete dead hang at the VERY bottom, and return to the VERY bottom for each rep.
- Do 4-6 sets of pull ups, then do one last set of negatives = Jump up or use a chair so you can start at the top, and SLOWLY lower yourself down. Immediately jump back up there and do it again several more times.
- Once you can do 10 true/clean pull ups, buy a belt and start hanging weight to make it harder.
