Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
At this point, I feel like the next logical step would be a Cummins swap anyway....so I vote for twins. EVERYBODY wishes they had a set of twins
At this point, I feel like the next logical step would be a Cummins swap anyway....so I vote for twins. EVERYBODY wishes they had a set of twins![]()
That’s more of a Jenner.
The 6.4 has twins and I want bigger ones
To be fair....6.4 turbos aren't thatttt big. They definitely spool quick though.
Damn I'm glad you decided not to go with that 1/2" plate!So the new stance of the rear axle of the truck is wiiiiiiide. I put my truck camper in the bed and I had about 1/4” of clearance between the tires and and the front jacks. So just like every other man, an extra 3” I figured would make me perfect!
I absolutely hate loading a slide in camper, even more so with the dually. I've often wondered about building a frame to lift the camper up from above, with winches vertically. Then you could set the camper on a stand to rest and even roof the frame so it could be in the dry. Sounds like it could be so much easier.
So a little update. I learned a valuable lesson not long ago: dont powershift from second to first when going up a steep gravel road when you are loaded up with the truck camper and jeep on the trailer... you can snap a D80 shaft
Dang!
Looks like a very nice Job. Who did the work?
So is 2020 the year it gets 4:10 gears?
4.88
