XJsavage
CounterCulture
- Aug 15, 2009
- Lyle's Ford SC
My thoughts exactly!Snowdrift vanilla porter is a great brew!
Yep. I'll settle for a 1350 CV driveshaft out of a 99-04 SD truck. I've got a full 1410 shaft for the front still sitting here awaiting funding for yokes.1410 next?
I'll have to find that one. Breckenridge vanilla porter is one of my favorites.Snowdrift vanilla porter is a great brew!
I have a stock driveshaft from a 2008 diesel F250 here if its useful to you. I think they are 1350, but might be larger. $20 and its yours. If I remember right, the joints are good too, but its probably been 4-5 years since I pulled it and swapped in an aluminum one.Yep. I'll settle for a 1350 CV driveshaft out of a 99-04 SD truck. I've got a full 1410 shaft for the front still sitting here awaiting funding for yokes.
How much of a nightmare do you think that would be to ship? If you get a chance to, if you would, post a pic or pm me. Thanks.I have a stock driveshaft from a 2008 diesel F250 here if its useful to you. I think they are 1350, but might be larger. $20 and its yours. If I remember right, the joints are good too, but its probably been 4-5 years since I pulled it and swapped in an aluminum one.
Well, its a 2 piece that's about 6ft long, so in that configuration, quite a nightmare. Of course i can just ship you the useful half. But I bet we could get it to ya via the power of NC4X4, even if you are in SCHow much of a nightmare do you think that would be to ship? If you get a chance to, if you would, post a pic or pm me. Thanks.
Just ordered forged 1410 strap yokes for the HP60 and 205.
As far as the rear goes, the factory flange style 1410 is the most logical way to go about it. I have one laying around some damn where.
That's even better. I would take both halves just for cut/splice spare purposes. It's actually a challenge to find a non-mangled one in junkyards.Well, its a 2 piece that's about 6ft long, so in that configuration, quite a nightmare. Of course i can just ship you the useful half. But I bet we could get it to ya via the power of NC4X4, even if you are in SC![]()
Walmart on G-ferry has it. Pretty sure it's a regional stock. The Yuengling Hershey's chocolate porter is also good this time of year.I'll have to find that one. Breckenridge vanilla porter is one of my favorites.
Ah. Thanks for the offer. The one I need is actually the front assembly that has the double cardan.@XJsavage
Joints are good. I believe they are 1410s. Its pretty beef.
View attachment 334276 View attachment 334277 View attachment 334278
I'll be 1410 all the way in the front. Shooting for a 1350 double cardan at the tcase in the rear and 1410 at the axle. I think that should do it.Seeing your blow up 13series stuff makes me really glad I ordered my case with 1410 yokes. I don’t have friends in the towing business. Hahah.
Are those 1350 or 1330?Try an early 90s Explorer shaft. I had Oliver's modify one for mine.
I'm pretty confident the 1410 will be fine in the front of mine. I've got a 1410 shaft already the correct length for what I need, and yokes in route. That should cover me there.I ran 1310 for a long while. After breaking a few. 3 or 4. I went to 1350 IIRC. Broke them too. I'm not at 1410 rear 1310 front. Never had a problem in the front. Most of my issues were axle wrap in the rear though. I did twist the double cardian section of a tome woods joint on it's first trip in '09. He sent me replacement parts too. Then broke them.....
The dodge has some dumb flange with spline like groves.I'm pretty confident the 1410 will be fine in the front of mine. I've got a 1410 shaft already the correct length for what I need, and yokes in route. That should cover me there.
Since my rear is already set up for a Double cardan CV style, I think I'll stick with that. I need a junkyard trip. Badly. 99+ SD front should all be 1350 CV style. I think Dodge 2500s were too.
It does now that I remember back.The dodge has some dumb flange with spline like groves.
