Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
Same here!
Got the old gas tank out, cut out the busted brake like that was (of course) behind the gas tank, made a new one, new rear brake hose, new gas tank in, new in-line fuel filter, new feed/vent/return hoses from the tank to the hardlines at the frame, and then bolted the new tires and rims on it. It fired right up. It's amazing how they'll do that as soon as you send some gas up to them.
Then I pulled it around to the front of the house, filled it up with water, and drove it to the end of the road and back! Oil pressure gauge, volt meter, and wipers don't work. They're likely a related issue and I'll dig in to that at a later date. I'm working on replacing the parts that I have and/or bought at the moment. After that, I'll start troubleshooting, but not before a good pressure washing...especially while the bed is still off.
Runs good though. Nice and quiet. I can't believe it doesn't have an exhaust leak somewhere around the manifold
Shocks, tune up parts, water pump, hoses, belts, and fan clutch tomorrow.
Thought about a 4BT swap, but if it does ever get a diesel, I'd like something smaller/lighter that's common rail.
