A rear shaft from Oliver’s made its way between the Atlas and the 14 bolt around this point. 1350 on both ends with a cv on the t-case side And their heavy tube option. Once the brakes were bled and the rear of the body wiring harness was back in place, the fuel tank and skid went in and a gas can got poured in. It fired right up and everything seemed good to go.
It successfully made it to the gas station down the road to get filled up. I drove back past the house and through town to get a few miles on it.
As I turned around to head home (I’m only 4ish miles away), the engine stumbled and starting running super rough. Then it acted like it ran out of fuel. No pressure at all on the fuel rail and I couldn’t hear the pump over the sound of traffic going by.
After deciding I wasn’t gonna be fixing it on the side of the road, it ended up on a roll back to get home. And I got a nice $70 tow bill.
Once I had it back in the driveway, I could hear the pump cycle but still had no pressure on the rail so I dropped the very full fuel tank and the 1/4” thick fuel skid. Popped the top Off it the sending unit to find a huge hole in the line between the pump and the regulator on top of the tank. All it was doing was swirling fuel inside the tank. One cheap Advance Auto sending unit later and it was back up and going.
if so.... lol
