- Mar 24, 2005
- Stanley, NC
ExactlyHow is this cone wrench any different than a regular ole open end wrench for this application?
Maybe if you bought two, cut one and welded it tot he first to create a “box end”. But at that point, just have something made anyway.
I’m guessing the desire for a box end is the mouth opening and wearing out?
I haven’t seen them in sometime now, but there was a 6 point box end wrench that instead of flats it had bumps, or maybe another way to describe was a wave pattern. It proclaimed to put pressure on the flat surface of the nut instead of the points of the nut. Made sense to me. But I don’t think you’d fit it on this with the curved ends. But you might could modify it to work.
Correct
Correct
It wouldn’t fit because of the wider diameter. Of it was a hex that would be the perfect tool. I know Kobalt sold them in some of their earliest offerings from the late 90s or early 2000s, but they were actually made by someone else. I’ve always wanted a set.
We would have to replace 2 of em every time this unit came in which is a couple times a week. Plus the head has to be less than 2.5mm for clearance in a reciprocating assembly. So it would have to be a custom made 2.5mm hardened shoulder bolt, and would probably need to buy a hundred at a time for good economy of scale, and then Germany would notice when I bought a hundred $40 voltsAnother vote for making a "tool" out of some plate steel or scrap from the shop. Then replacing said bolt with a normal hex head shoulder bolt.
Then you don't need a $$$ tool to fix it the next time.
@Andy J. Knows some of the battle I’m facing
Definitely just bigger it up.Do you think one of these would work, or just bugger it up?
Would require too much modification and is still an open end.Curses! Why did you have to lead me down this rabbit hole?
Would something like this work or would it have to be fully closed? You could mill out the flats on the handle end to fit (or clear) the radius of the head? I guess that still violates the off-the-shelf rule, but we’re getting desperate here.
Well lets just say, if you think getting yelled at for not holding the flashlight still was bad.......
