"Take 92" - YJ Linked with Nines
Trying to add better tool storage
With back issues continuing i did the easy stuff, paint more :)
Crossmember replaced, driveshaft mount reinstalled, new tail lights, oil change, rear diff sealed, lock out hub replaced.
Making progress as I get ready to drive to California for some wheeling
Best customer service in a while.
I reached out to Andy @ironman4x4fab and ask for his transmission mount.
He made it that night and shipped the next day and i was able to install it today
Pic of mocking it up
I had to modify some due to clearance issues
Added some better storage in the back
Pack out and fluid holder installed. And new air intake
Add a reciever hitch to rear bumper. As I wanted a way to support rack we built for back to help carry stuff
Replaced the steering heim joints and also drilled and welded in new weld washers all from Barnes
Jeep is finally on all 4's ready for it next adventure
California here we come. We leave next Thursday for the ultimate offroad adventure with Build for off road
Well we had a blast. Wheeled Johnson Valley and trails in Arizona
Tried backdoor and failed. Just could not get front tires up enough to grab and pull.
But everything else was easy :)
Well it is time to fix the yj
Dropped skid plate and took dana300 bottom cover off and to my surprise all the gears look great
So now I need to pull it out and upgrade
Gonna use this
Magnitude 300 new case and shift rails
Time to upgrade
Jeep on lift and ready to be worked on
Ripped apart stock 300 and started assembly of the new case and realized I need to pick up a seal and a bearing. Can't find the ones I had oops
