Let's See YOUR DODGE!
that truck is mine now and it looks like this:
24s! put the 24s on!
Here she is with around 7500 into the transmission now and new tars. Happy to have it driving again.
with that much coin in the trans we need videos not pics. lookin good man...
Ok guys I am back in afghanistan for my third and hopefully my last time but while Im out here I am going to by an exhaust manifold and turbo for my truck,just wanted some opinions for what turbo to go with with my upgrades?Here are my upgrades:
03' 2500 QCSB 6 speed,new injectors w/ 120hp nozzles,#110 hamilton springs,stage 3 cp3 industrial injection,AFE intake & manifold,4"magnaflow exhaust w/ 5"tip straight piped,Smarty S06 POD,Airdog 150,EV2 boost,fp & pyro gauges.
(coming soon:rebuilt 3850 SB DD clutch)
Also have 3.73 gears and 37" tires.Im thinking about going with a 64 turbo.
A guy on cummins forum has a HTT 64/74/14 and is telling me with the larger impeller it will be awesome with my 6 speed.
Any info you guys have would be much appreciated!
I finally took a shot of my turd to put up on here.
4" rancho, 35's & 18's HEMI, other than that its pretty much stock.
MarsFab I pass by your shop crossing the railroad tracks a couple times a week. I saw yall hanging out there tonight around 7, I was in a white Chevy on 35s pulling a landscaping trailer. Good looking truck
Don't try to save money on an exhaust manifold. Go ahead and get an ats or something comparable. I just put an AFE stainless on a guys truck and I'm having a hard time getting it to seal on #3 and #4 cylinders. It's a single piece.
On my yellow truck I was running a 62/14/71 SPS from Industrial. Go with HTT when you buy one. I was very happy with the size of it until it exploded. The clearance on the II is a little more than I think it should be. Way too much play in the shaft. You should be in good shape with one the size of mine or bigger. The bigger you go the more you're going to get into surging issues though. Do you tow much?
Well I hear ATS is expensive for comparable manifolds but I have seen a few deals,one guy has a HTT stainless 3rd gen but I really want to do the 2nd gen swap.
What mods were you running in your yellow truck?i dont want to go to big but everyone is telling me the 62 is too small for my mods.I do tow my toyota to the trails and other things every now and then.I have found an awesome deal on a HTT 64/71/14 I have heard the 14 compressor for my truck would be better and since I have a stick it will be easier to keep it spooled I just dont want to be cruising town and blowing crazy smoke cause I cant keep it spooled.anyways just want some good advice.thanks solar!
Oh and by the way my truck still has an electrical problem and still in the shop haha! but I figured since i would be gone for 6 months or more i would go ahead and get a turbo to match my mods when it FINALLY gets out of the shop!lol!
One more option is an offering from Borg Warner-
63/68/.80 T3 (~14cm, iirc)
http://www.diesel-plus.com/dd_turbo.cfm?npid=10211
Note: this charger requires an HX-40 outlet flange (and DP mods to connect), and a $2 oil adapter fitting.
I HEARD that it's the cat's meow, but dont quote me on that. The guy at the Tampa location of Southeast Power Systems said the 68mm turbine is better than the 71 (newer design)
Although not a near comparison, I will be hitting the dyno with a 63/68/.88 T4 turbo this weekend
My yellow truck had 50 hp ddp nozzles, Smarty, Quad X2 Race with stack tune, ATS manifold, AFE stg 2, AFE bladerunner, Airdog 150, II SPS 62/14/71.
With your mods I would definitely go with a 14 and a 71. The 62 spools very fast. When you go up to a 64 or 66 you will have a little more lag. And having a stick will make it harder to keep spooled. I think you would be safe with a 64. I think a 66 would be a little too big and you'll have surging issues. I just installed an HTT stainless turbo on an 06 and I am very pleased with the results. It will handle a lot more heat than a cast iron housing. Unless you're planning on doing twins later, I think going with a 2nd gen manifold will be more work for nothing. You're going to have to change the downpipe and cold air if you do that. I'm really not crazy about the new stainless manifolds because they are one piece. I like the two piece manifolds because they can move a little with the heat and there's less chance of an exhaust leak that way. Also do you have an exhaust brake on the truck?
thanks for the info solar,why not do the 2nd gen swap?Everyone I talk to says they make the 3rd gen sound awesome!but yeah i got a buddy that has done the swap and he was going to help me.
I do have an exhaust brake on my truck travis had it on this truck when I bought it from him (since you guys do live in the mountains) I have been wondering if I can keep it on there cause I have heard the new turbo might get in the way.
Well do you think i should go with the 62?I just figured as much fuel as I will have now I would need more but it is my daily driver and I dont want alot of lag.Just trying to figure out whats best before I waste alot of money on a turbo that im not going to be happy with.
The only reason I wouldn't do the 2nd gen swap is because of having to do more work and spend more money for nothing. And you will more than likely lose your exhaust brake. Is it a pac brake or jacobs? If it's a pac, you should be able to keep the brake if you do a 3rd gen manifold and turbo, but if it's a jacobs, it more than likely will not work. You should be fine with a 62 or a 64. Give HTT a call and see which one they recommend.
the dually is sold...onto something else
Thats awesome man I never thought you were gonna get rid of it!lolI hate it at the same time though that was a sweet truck!
whats the difference bettween thos brakes?Might sound like a dumb ? but I have heard the terms.it was a add on with a switch on the shifter.Its a BD exhaust brake though.
