khwrx
Active Member
- Dec 10, 2006
- lincolnton nc
what kinda car did your wife have, integra ls or gsr???
how much HP does that 2.3 have over my 2.2?yours being aYes the trac bar mount is VERY close to the shock, but I cycled the suspension and it won't hit. I had to do something to make the trac bar longer, I had made it way too short when I first did it.
The new injun! Made the rear motor mount (pictured), will try and make the mount on the drivers side fit tomorrow to be ready for a transmission.
), couple floorpans are cut to fit, lower link mounts are done.pretty much NOTHING honda tranny related is cheap....
thats great your making some progress,i got burned out on mine,so after a few months break i started back on it.got it finally running,still a month or so before its wheelableThanks to Daniel, Greg, Jason, and JC for the help last weekend and today. I need to post up some current pics, but an update of stuff thats been done to it is:
Skidplate is cut
Power steering and radiator overflow resevoirs are mounted, power steering cooler and radiator mounted, tubework on the rear is finished, grille is mounted, dash is fitted (crooked holes and all), couple floorpans are cut to fit, lower link mounts are done.
The point is, it's being worked on and should make the March 20th race...
Go ahead, rub it in. I`m used to drilling bar tops not 3/16th aluminum plate. Dang hole saw had legs on it.dash is fitted (crooked holes and all)
Not coming to DPG, working on the buggy instead.
