- Mar 17, 2005
- N. N. Raleigh, NC
Did you try taking that extra tin/metal strip that is pushed on the edge of the mag part? That should give you a little more room for a fatter bead.
I guess its time for an update...
Pic shows the suspension at full bump. It'll be up about 6" more when I air up the shocks
suspension completely installed, fuel cell installed, wheels and tires installed, trans, TC, and engine installed, radiator installed and plumbed, steering installed, rebuilt front and rear axles
Next: finish the fan shroud, add some bracing, mount pedals and sheet metal, wiring, hydraulic hoses, fuel lines, install axle gears and driveshafts, install lights and winch.
list is getting shorter.
Oh yeah, paint and stickers![]()
I now mine sure didn't like going fast for very long....they got hot and wanted to extend all the way out after a few miles. Wonder if you could make them remote resevior somehow?wait, your running airshocks? and your trying to do KOH![]()
Looking good, Rob.
Looks like you need some of those rim stiffeners you've been pimping on PBB.![]()
Man, with that kind of unsprung weight and as big as your chassis itself will be...air shocks don't stand a chance. Maybe foa will cut you a deal on a set of remote resi's? Otherwise, time to take out another credit card.![]()
Maybe I'll just have the spare set in the pit and change them out when the first set fades...
