Mac5005
- Oct 19, 2005
- Rocky Mount
Is that square tube or angle iron on the a pillars?
You're gonna kick my ass i bet:Is that square tube or angle iron on the a pillars?
ON A SERIOUS NOTE AND QUESTION:
which style Doubler would be the better route to go, i have the materials to do it both ways but have mixed facts about which one is likely "stronger" thank you
either option A (something similar to this divorced setup)
or option B (exactly this type setup)
thanks for response...
please don't tell me not to do doubler cause it's getting done either way, have gathered materials, extra case, just looking for anyone who might have done one of these setups and could vouch for one of the setups...
btw, i went this route cause it saves 600 not having to buy the kit
My question is why have you been banned twice?few pics of the flex so far...it goes better but that's all i can get from that hill and the rear finally stuffs all the way up in the wheel wells...not bad for hack job lift kit and 3cherokee rear leafs combined together
View attachment 211031 View attachment 211032 View attachment 211033 View attachment 211034 View attachment 211035
Time to revive this "Abomination XJ" build: add ons since last post lol. Turning into one awesome XJ, at least I love it and my most favorite XJ Toy yet!!!
flat bottom rock sliders (freaking awesome how they tuned out)...roll cage tied in to them too
D44 front & rear 4:09 geared
homebrew front bumper $10
homebrew rear bumper $10
interior Cage....NOT FINISHED but something to start with...laugh all you want, better than nothing
body armor.. was bored, had scrap stuff and needed something to do with the new plasma cutter lol
I'm not posting this to get likes...just giving everyone some good laughs for a while ....that is until my doubler gets done, I'm making it too
View attachment 211007 View attachment 211008 View attachment 211009 View attachment 211010 View attachment 211011 View attachment 211012 View attachment 211013 View attachment 211014 View attachment 211016 View attachment 211017
Pillars in Front are 5/16" C-channel, piece going across dash area is 4" round 5/16" whatever it is, shc40 going down through floor into rock sliders, behind front seats is sch40 and then 1/4" 3"angle iron going across top, behind rear seat above is 1.5x1.5 1/4" square, piece in rear hatch is 4" 3/16" square with sch40 running off that to top and to very rear pillars, very rear pillars has 3" angle iron 1/4" going across top with 5/16" 2.5"round tube going down into 8" C-channel welded to unibody frame rails with plate attaching those c-channels together...all welded and all FREE
I am the last person who should be giving welding advice, but I would weld that tab solid to the truss.
You need to choose the one that:
A- won't snap the rear half of your transmission off due to weight
B- won't cause your driveshaft angles to be fubar. Especially the front.
C- will allow you to run upgraded output shafts
D- will keep your front driveshaft from making sweet love to your first transfer case
E- will actually fit under an XJ
F- I could go on but it's bedtime in Horse Shoe NC.
Does it really matter? He has plenty of overlap and its parallel to the ground and drag link when it's at full flex. That's the goal, right?The front trackbar looks very questionable. How far is the original solid bar inserted into that tubing?
it goes in almost all the way...i only had to do what i did because i wanted to add about 1/2" space from the top of it so doing what i did gave it enough angle downwards to clear the housing betterThe front trackbar looks very questionable. How far is the original solid bar inserted into that tubing?
it is...those pictures were when it was mostly done in the shop...i have since finished last few brackets to strengthen and added another piece to my "cage"I am the last person who should be giving welding advice, but I would weld that tab solid to the truss.
well option A is a given...no matter which route i take I will have to make 2 separate mounts for the second case since it's not "properly being bolted" like the fancy kit comes with so weight shouldn't be an issue with whatever double (maybe a third on the fist case) mounts that I doSO you are leaning option A, right?
i don't like my trackbar any better than you do lol but it's what i had to do for now. gonna order me a adjustable or find good used one when i get a chance since i fluctuate with my lift size so much but for now it works as bad and half ass as it may be.The front trackbar looks very questionable. How far is the original solid bar inserted into that tubing?
i have 2 other track bars that i've acquired since then but don't have time right now...hope i will have one put on before the first April rideIf it's worth doing, it's worth doing right. Especially on that track bar.
it's "almost level" lol. It ended up being off 4/5* maybe but it works. The way that i do my stuff is:Is the top of that c channel "truss" even level? Some custom "geometry" we don't know about yet?
