WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
Spoiler alert....
I'm not up on trailing arm design but wouldn't it be better to have the bottom of the arm to be a flat straight line between the mounts and the boxing and shock bolt mount above the flat smooth bottom of the arm? For sliding over rocks, logs, Hillary supporters etc... easier.
I did not think about the link wanting to twist, that's good info. ThanksLol. There are a couple trains of thoughts, many ways to do it. If you run a straight bar with shocks mounted above the center line of the heims, you must run a wobble stopper at the chassis, or other shock mounted bushing accessory to keep the link form rolling sideways and damaging the shock: i.e. broken shaft or mounting post. With the lower shock mount below the center line of the heims, the spring preload well keep the link from rolling over. Both ways work and are successful in motorsports. I like the canoe style, but if i see they halt forward progress too much, I'll build something different, something like Will Carter built for Sam below, well proven.
This is how 74_chevota did it
This is your traditional wobble stopper from kartek, $, plus the cost of the uniball.
Unfortunately easy isn't in my vocabulary
Matt
Happy to share buddy.I did not think about the link wanting to twist, that's good info. Thanks
For real, thinking about skipping the spare for now, in the sake of time...lol. have about 15 hours in this arm when done.if you break those you are really doing something![]()
What happens when water gets down into the box area where the coilover goes?
Figured you had it figured out![]()
Drain hole
Matt
Thanks. Ran out of time today, will measure in morning. With our without heims?Nice work going on here. Working in the measurement industry.....what does that arm weigh?! Just curious.
Here ya go!Nice work going on here. Working in the measurement industry.....what does that arm weigh?! Just curious.
