loose cannon
- Oct 1, 2007
- MARION
Now that's bad ass
Then jump in the diesel and peel out.
Gonna run baffles in the tank? I know the gm pump has a sump but Im leary of all alum cells now, after the RCI issues.Fuel cell tray is done
Digging the Goatbuilt cell, can, and fast fill plate for factory gm internal fuel pump.
Matt
Fuel Tank Kits – Goat BuiltGonna run baffles in the tank? I know the gm pump has a sump but Im leary of all alum cells now, after the RCI issues.
Damn Skippy....Hell to the yeah! Dude the rig is sick. Can't wait to wheel with you again.
Good times and food shall ensue...
Awesome. I have looked at the goosebumpsFuel Tank Kits – Goat Built
It's an .080 aluminum can around an 18 gallon poly tank. You can order just the poly, with our without straps and tray, can or no can, and 4-5 different fill plates. There is a huge o-ring that seals the fill plate with blind nutserts molded in the poly tank. Also uses blind nutserts on the pump ring and filter plate.
Best feature is the use of a factory gm fuel pump with its excellent scavenging system with a venturi pump for the "accumulator" canister...and can be found at any parts store for equal or less than any external pump unit. Walbro even makes a higher output version for more ponies, which is about the same price as stock.
You can see the o-ring groove here
He even sells a poly replacement for RCI 2161 faulty tanks, with the fuel pump option as well.
Matt
Edit- if I race, I will have to run baffles per rules.
You got a problem with us people?Dude you don't even wheel!
Yeah guys like you causing a shortage of good jackstands lol.You got a problem with us people?
That's an expensive pencil holder.![]()
Damn straight...That's an expensive pencil holder.![]()
