YJJPWrangler87
- Mar 12, 2006
- Raleigh
Well, the time has finally come to start the buildup on Amanda's(xjgirl92) cherokee. The specs will be: Rusty's 6.5 leafs for the rear, RE 4.5 Coils up front with a custom 3link kit and 33's to start off with. We still need shocks, extended brake lines, most likely gonna do a RE HacknTap
Heres what we started with...
We built the LCAs at a friends house, he did all the welding for us. Hes built race cars/dune buggies all his life...so the welds shouldn't break...Welding up the LCA Mounts
And here is the LCA mount with the RE builder ball mounted in it
After we fabbed them up, we bolted them up to the unibody
After that we stitch welded them into place. After the LCAs were mounted, we started to fab up the one UCA mount...since its a 3 link, if the top link fails..buh bye front axle. We had planned on making the RE Joint horizontal but couldn't b/c it hit the DS so we came up with another idea to run it vertical...Here is the UCA being fabbed up. It will be held on up 3 grade 8 bolts that bolt through the unibody.
