So I need some wiring help. Any GM GenIII guys out there?!
I have been removing my wiring harness using the steps from Lt1Swap.com and I am ending up with a few wires for each plug. So here are my questions....
First off, I'm running an SM465 tranny so no auto tranny stuff needs to be on the harness. And I won't ever go to an auto because I like shifting gears. Should be fun with a right hand drive setup.
I'm also stripping all the A/C components, EGR and emissions related stuff.
Can I remove the sensor that mounts to the side of the oil pan without an issue? I read in someone else' build that they were able to remove it since it is only read by the PCM but isn't actually needed for the engine to run properly. I just thought it would be cleaner with no plug and wire hanging down.
Also, do I need the cut wires that are in the pic below (the ones on the left side of the image? They were cut like this from the harness from the engine I got so I don't know what the plug looks like but I thought you guys might now off the top of your head what they are for and if I need them or not.
Any help is greatly appreciated.
![Big Grin :D :D](/styles/nc4x4/xenforo/smilies/biggrin.gif)
