So I need some wiring help. Any GM GenIII guys out there?!
I have been removing my wiring harness using the steps from Lt1Swap.com and I am ending up with a few wires for each plug. So here are my questions....
First off, I'm running an SM465 tranny so no auto tranny stuff needs to be on the harness. And I won't ever go to an auto because I like shifting gears. Should be fun with a right hand drive setup.
I'm also stripping all the A/C components, EGR and emissions related stuff.
Can I remove the sensor that mounts to the side of the oil pan without an issue? I read in someone else' build that they were able to remove it since it is only read by the PCM but isn't actually needed for the engine to run properly. I just thought it would be cleaner with no plug and wire hanging down.
Also, do I need the cut wires that are in the pic below (the ones on the left side of the image? They were cut like this from the harness from the engine I got so I don't know what the plug looks like but I thought you guys might now off the top of your head what they are for and if I need them or not.
Any help is greatly appreciated.
I'm also stripping all the A/C components, EGR and emissions related stuff. Can I remove the sensor that mounts to the side of the oil pan without an issue? I read in someone else' build that they were able to remove it since it is only read by the PCM but isn't actually needed for the engine to run properly. I just thought it would be cleaner with no plug and wire hanging down.
thanks again for cutting that piece of plate for my build. Let me know when you want burly and I to stop by a put that body back on before the neighbors get pissed!
