Well I haven't gotten a ton done on my postal this weekend. I thought I found the issue I kept having with the slapping sound that was coming from the transfer case so I tore the t-case apart again and put a new heavy duty chain in it. Well....it didn't fix my problem so it looks like it's the driveshaft and/or steep driveshaft angle that is causing the noise/driveline vibration. The shaft I'm running in the rear is just a cheap shortened XJ shaft. I'm going to call Oliver's Driveshafts on Monday morning to see if I can get a high angle shaft from them for it. If they offer a quick turn around I can still have it ready for Uwharrie this coming weekend. Even though it's looking like Uwharrie might be closed from this stupid gov't shutdown mess.
Any of you guys had to deal with driveline vibration from a steep, rear short driveshaft? Any input is greatly appreciated. I'm not sure how to fix it. My pinion angle is set to accommodate the less than 2* difference in the shaft like it's supposed to. I can post up pics if you would like me to.
Once I got the t-case back in this morning after the rebuild. I helped my buddy get his rig ready for some fall wheelin' too. I started fabbin' some frame plates and front shock hoops for my buddy's TJ. Yep it's got leaf springs!
My last shock hoop design failed so I made sure we overbuilt the hell out of these. Hopefully no more issues! Here are some photos of the sequence of building his hoops. I was happy with how they turned out.
Frame prepped and ready to go.
Frame plate I made, cleaned up then tacked in place with holes welded.
Welding circles is fun!
Another.
All done ready for paint.
Another.
