Light weight Toyota buggy build
2.0 or 2.5 springs, what weights do you need. If thats all you need you are welcome to use my springs. My rig is done for maintenance.....
Also I have all the stuff to wire it if you need anything let me know or bring it to the shop and we can knock it out!
Almost forgot I have to finish the exaust also had these laying around there carbon fiber so should stay pretty cool I'm going to move my propane bulk head over just to make me feel better
Got a good bit done tonight finished up all the plumbing and got my panel installed going to to add fluids to everything tomarrow and see what leaks
Lights came in today got them mounted had to special order them 35w 2700 lumens each but they are bright as hell
Well got some more work done tonight got the brakes bled and working got the clutch working but the pedal is very stiff I got a new 3/4 willwood master I'm thinking that might not be right got the radiator filled also and found a leak from where the heater hose go's into the block so I had to pull the alternator and get that all cleaned up i. Going to let it dry over night and silicone it up in the morning
Jonathan came over and we got some work done this weekend
Got the exaust finished up today and got my new xrc8 winch on Wich made getting the buggy loaded alot easier 9n the to do list is 1. Wiring Wich should get done this weekend gas pedal and stering wheele and shock springs I'm going friday to use my buddy's race car scales but I'm going to have to save up to get some springs Holidays have hit the wallet pretty hard
Had to do a little chassis painting today surface rust was killing me
Got it wired up and and even drove it onto the trailer today big thanks to snappy for the help still lots of bugs to work out But it's getting there
Bring it on out to DPG next weekend. Loving this thing.
Jonathen cam over and helped me button up some loose ends buggy was pretty much ready to ride other then shock springs noticed I had some exaust pressure in my cooling system pulled the valve cover and found a broken rocker arm holder I don't think the two issues are related not really a huge deal but dose suck
Well this kind of snowballed pulled the head and found a gasket failure found a Crack in the front cover Which where no big deal pulled the rod and main baring caps and they where tost so ended up pulling the motor last night I didn't have a hoist luckily jonathen and dustin where here to help thanks guys
