Mr. Ed buggy
If the tank is a right angle triangle its easy to calculate the gallons.
(LxWxH)/2 that gives cubic inches, then multiply by (0.00432900432900433) for (US)gallons.
well, did the math and i'm at 10gals. thats about what my last buggy was with a big block. so i should be fine.
Those wheels are hot. Keep up the good work - it's looking great so far.
Since you had a whole week to work on the BEAST....I need to sneak away from the shop and see it......Still want to paint it Victory Red...? When you have a chance give me a call.....I need to look for a 4.0 head and EFI System....:bounce2:
well didn't have quite as much time as i would of liked. but yeah victory red is the color.
update
got floor and center counsil figured out. floor unbolts to access all the goods. tranny and tcase will be pulled from the inside.
couple more.
as you can see had alittle seat fire.:shaking: but i am going to recover the seats anyway.
I like the single pedal. . . I am sure its not the brake one either. . . Tim looks great. I may try to come and check it out soon. . .
thanks guys, wish i had more time to work on it. can't wait to here those turbo's.
yeah it back fired on me. luckley no one was sitting in it. no had to do with a plasma cutter, in the rat rod buggy.
just talk to a guy that has real world expierence with turbos on ls motors. he says 800hp all day long on stock block stock bottom end and has dyno sheets to prove it. it was good to here it from someone else.
dash
was able to get dash done. the dimpled part will be where the switches will be.
almost. no just trying to get all the other projects around here finished up. hopefully this weekend i will have some progress.
yours is looking awesome.
