NickMaul
- Jul 4, 2009
- Norfolk, VA
Rouche creek is a possibility.
Count me in
Yes, I am a huge fan of H1s. 3 more to go
RBD rig #4 is getting prepped. Jason Chancey would like to play.
I've decided to put a bookmark in Steampunk atleast until early December to focus on getting the village rigs up and going.
Before anyone panics, it's 98% complete. The next person who asks me if or when Steampunk is going up for sell can go fondle themselves.
2018 is going to be a rowdy year.
Maybe some axle work involved? (starts at 1:16)
Well, they DO have three times as many bolts as my old set. I figured with only eight bolts, I should probably put them together like they were supposed to be assembled. Never had any leak issues and I had a metric fack ton of o rings for them, which was nice.
You won't be able to add airsoft bbs through the valve stem. The hole is too small. Standard bbs work but be careful with pulling the valve cores to air down. They will shoot out at you on occasion. I had a set of 12 bolts that I completely rebuilt with new studs, orings, valve stems, etc. They looked great but I had the hardest time getting them to seal.
I always run a bead of silicone in the oring groove or coat the oring with it, when i am putting them together. Let it tack for a minute and put them together.
We always used the most nasty stinky axle grease and coated the ring and both wheel half faces. Seemed to always work. The bitch was the stupid 1 piece rubber runflats. Those things can kiss the darkest part of my ass!!
Call it what you will. Rather than waste time and space arguing with children, I'll simply delete what comments I've made recently and replace with contents of this build thread (mostly tech).
Curious to see how this goes.![]()
Yeah im pretty confused. Did Diners Club push OP over the line?
And then there's always my beloved aluminum stick. I'm scarred for life.
