justjeepin86
- Jul 9, 2005
- Winston-Salem, NC
Much better!!!
Any thoughts on the difficulty of a real sheet metal gladiator swap? It is on my bucket list for my YJ.Had some people ask about YJ to CJ swap.. IT IS NOT just a bolt on mod.
Hood is shorter, grill does not mount in stock frame hole, yj radiator will fit if you cut up the cj grill some so it can slide in, and once you do that the CJ headlight buckets dont fit due to yj radiator being wider. I also had to cut yj fenders and take 1.5" of of them for them to fit to grill and look correctly. SO no this is not a 20 min job.
but when done it does look cool
amazon LED 9"what headlights did you use? Do they mount in the factory buckets, or just off some tabs?
anything is possible with a welder and time.. but measure hood length and see how grill mounts. once you have those numbers the rest can be figured outAny thoughts on the difficulty of a real sheet metal gladiator swap? It is on my bucket list for my YJ.
Just a few notes if anyone is looking into this swap. Cj fenders work to get everything to line up easily if the value of time > money. I had to make a custom rad mount from angle iron since the power steering lines intercept a cj radiator so you canāt just use a cj rad (I wasted $200 on this oversight). Yj/tj have a narrower rad core and a cut on the corner but the overall package is wider. You will also need an electric fan as the hood is too short if you run a 4.0, Iāve seen people get away with mech fan on v8 swaps though. shortening the upper grill supports is also needed i sleeved mine with tubing after cutting 1.5ā out.Had some people ask about YJ to CJ swap.. IT IS NOT just a bolt on mod.
How many years you get out of a rebuild on the air shocks
I went thru them 5 years ago, so I am.hoping to get another 5How many years you get out of a rebuild on the air shockers
Excellent work by the cameraman, staying on target, smooth, and moving around visual blocks to get the full vid!![]()
We also did Walden ridge and that was a little sketchy alsoYou got incredibly lucky you didnt wreck into next week. That is the most sketchy spot on the whole mtn in my opinion.
Thatās my favorite trail at WindrockWe also did Walden ridge and that was a little sketchy also![]()
