89wrangler
Not a new member
- Oct 22, 2005
- Bostic,NC
you guys need to do more working and less posting, burning way too much daylight on here.....
Not me. I just came in from the garage and have to be up at 5am.you guys need to do more working and less posting, burning way too much daylight on here.....
what pump are you running?
You have 2 options for the pump.
You can put a bigger fitting in the stock resi of the pump or get another resi for it
http://www.polyperformance.com/shop...IC-Feed-O-Ring-Side-p-29314.html#.Ul8RsDPD_qA
I'm running a stock pump that I did the Texas Offroad mod to.
I think I resolved my problem! I did my idea I talked about earlier. I put an extention hose on my stock resivoir and put an aluminum stopper in it w/ a 3/16'' vent hole and blocked off the vent on the PSC resivoir. It worked like a charm from the first time I tried it. I mean it worked perfect. It was super smooth even at a low idol. It was just as I figured not quite 4 full turns lock to lock.
I didn't put a cooler on it or run the return through my radiator like I'd planned. I'm hoping going w/ the larger cylinder will keep the fluid cool enough to not put a cooler on it but we'll see.
I don't particularly like the extension hose sticking up like that but I had to do what I had to do.
Had to get my gauges ran so I fancied up the dash a little before I did. Also started on some of my switches. I'm sure that panel will be full of switches before I'm done. I still need switches for my push button start, winch, rock lights, fans, master switch, and a few more I'm sure.
so your running two reservoirs?
You need a PS cooler.
Thanks. It's took a long time but it's finally coming togetherJeep look awesome Ken!!![]()
correctThey will try to equalize. With the return going only to the extra resi, the integrated tank will rely on the other tank for fluid. If it's only 3/8" hose between them, it won't feed fast enough.
If the return is fed into the integrated resi, the extra resi is just supplemental fluid.
With it setup like Kenneth does & the psc vent plugged, it basically becomes a expansion tank inline in the return.
man that thing really turned out nice. you done a hell of a job kenneth.
I just stuck it there to keep it from flopping down in the belts.Hope you pushed that Blue line all the way up on the barb!
NICE JOB KEN![]()
Everything is looking really nice.
Can you reach that panel with your shoulder belts tight? If not i would put the starter, ign, & main power switches somewhere else.
I checked this afternoon and I can reach all the switches pretty easy so I shouldn't have a problem.You don't want the engine to cut of in a hairy position and not be able to reach the starter. Or not be able to cut it off in a rollover.
Why not wire up the factory key switch?
