rockcity
- Apr 10, 2005
- Greenville, NC
I forgot, you are in a crazy expensive area to build right now. So yeah, it’s going to be higher than I expected.
Easy.Why not just use fire proof lumber that falls off the truck?
Right now I rent 1500 sq/ft and split half another to store our camper.2011 price on my shop was just under $15 a foot for 24x32x12 with a 18x10 garage door, a man door, and 3 windows. Siding to match the house, 30 year architectural shingles to match house, all stick built cut into the slope with concrete block below grade. Price includes the garage door opener I supplied, all the electrical materials that I wired myself and grading. 3 years before when I built my house they wanted $40 k to build what I have so timing is everything IMO.
@Jody Treadway I know you can do a lot in a somewhat small shop but I don’t think anyone has ever said I wish my shop was smaller. Get it on paper, layouts are important for efficient work spaces and flow. Be sure to place doors so you can easily get RV and loaded trailers in and out. Just my.02
Sounds like you are going to fill it up up fast. Go big or go home! Plan for future expansion and ways to move things in and out with ease. Who want's to move 4 rigs to be able to weld on one?Definitely do not want that. This will be a long term property and I want a shop of my own. We live in our "forever" home at this point. So I am ready to drop the coin on my dream shop. Somewhere to keep our camper, my rig, my tow rig and still have room for projects. I'm a buy once, cry once kind of guy (but on a budget).
Unless you have a 12 foot tilt Bed Gooseneck Trailer, you're gonna want more than 40ft to accomplish that. Mine is 34ft, and with just a crew cab shortbed truck, it feels very crowded.Right now I rent 1500 sq/ft and split half another to store our camper.
2k is the minimum I'll build. I want 40' depth so I can pull truck, trailer/rig in or truck a d camper in.
I appreciate the info bud.
I'm interested in what type of propane heat you are running? Wall mount furnace maybe? BTU or size? Thermostat regulated?I built a 50'X56' about 15 years ago ky steel truss building it cost $50,000.00 then but I have 3 bay doors 2 on one end and 1 on the other so I can get air through in the summer months with a bathroom and office. I like my set up my floors are 6 to 8 in thick so I can pull heavy equipment in to work on when needed. It is insulated and the cost to heat it in the winter is about $1000.00 a winter to heat it with propane we are in there about 12 to 16 hours a day.
What about doing pex loop in the slab for radiant heating?
Insulated under the slab?
lp/ng water heater with circulator pump? Doubles for warm water for washing the pups.
If done properly in floor radiant can be incredibly efficient. My house I owned in Michigan had infloor in the basement (3/4 sunk with a walk out door on the back wall) The floor and walls were poured as one pour and the loops went 2’ up the walls. In the deepest part of the winter the furnace barely kicked on for the main floor living area.What about doing pex loop in the slab for radiant heating?
Shop style.I'm not sure on the btu's on the furnace I will check and let you know on that. it is one that hangs I know is a 1980 model heater and run's on 110 voltage. I got it used from our local recue squad when the put new ones in about 15 years ago. My garage has insulated doors but half of the doors are single pane glass. I got them from the city fire department when tore their fire station down to build a new one.
Information is information my friend!Shop style.
am not who you quoted, but I will chime in. I have a 90k btu furnace, wall mounted on a stand, and it heats my 40x60 very well. It is on a thermostat that I keep on 45 when I am not there. I kick it up to 60–65 when I go to the shop and it takes about 20 minutes to warm it up. I used about 100 gallons of propane last winter.
My dad is a HVAC guy, he removed the furnace from a house trailer when he put a heat pump in.
Home model.
Hmmm pros and cons?
Sorry for the highjack @Jody Treadway
