Nothing worse than bolting beadlock together and then realizing you forgot valve stem. Had to pull entire thing apart
Thanks I keep a set in the jeep just in case.You might want to look at these. I've heard good things about them.
Colby Valve Shop - Emergency Tire Valve - Replace Broken Valve Stems
One thing I forgot to add was we only have 4 in the stock class qualifying so that means even if I finish 4th in qualifying I also start 4th in the class which puts me in front of 26 other rigs in my class. last two years I started 2nd or 3rd from last.. this will be a nice change as long as I can stay in front less traffic on the rock trails.
I just realized my Nephew gets married in FL on the 8th. I'll likely be traveling on the 7th. You guys race on the 6th?
Put new fox shocks in and drove it around neighborhood pissing off neighbor jumping speed humps
I cant quite get a reference of size from the pic, but JK d44 based?
ford F250 dana 44 cut down and modified
Awesome. Hopefully all the upgrades will give you guys what you needed to finish on top at KOH.
I noticed the 8 tires, are you planning to put more than 2 in the jeep with you, or just have them on the lakebed if needed?
Interested in why not a 60 for strength?ford F250 dana 44 cut down and modified
I think its only the body/frame and engine and trans that has to remain stock.Probably limited by the class he races in. I keep hearing the word “stock” thrown around.
I could not find a 60 front I could afford. So I did a 44 one that I could.Interested in why not a 60 for strength?
