I would plan for at least .003-.005 which is only on the radius. If you have that piece hard coat anodized like you should thats another .003. Hopefully you not drawing any of this chassis that tight.
Oh, we did a test run on some metal with the lower control arm a while back. Everything checked out. The digital model is good.I still want to see real metal. When will that happen?
So are you planning to build this on your own dime. Or try to find someone to front the cost?Oh, we did a test run on some metal with the lower control arm a while back. Everything checked out. The digital model is good.
This thread is so entertaining!
Can't wait to see who all is in this "theorizing group"Hopefully they're theorizing where they can each get 100k to pitch in, otherwise its just a digital art project.I'll probably pen this drawing as far as I can push it, and then group up with some people that can finish theorizing everything I can't figure out.
What's going on here:Absolutely insane amount of work into this upper control arm, but I think it's done. I would never be able to create something like this by hand. Motobilt technology opening up doors for some speed. The hard work is done. Unbelievable.
That rear tire recombobulation mode is sweet!
