skyhighZJ
- May 31, 2012
- Aberdeen, NC.
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Wondering how the tile will do while rolling down the road. I know these things are not ridged and flex a good bit while being towed. Is there a special way you install it to keep it from cracking off?
be aware if rv sits in the sun for long periods of time that sticky stuff has a tendency to unstickIt’s just peel & stick, not real tile so it’ll be fine. I def didn’t spend the money on real tile for a mattress box on wheels lol
be aware if rv sits in the sun for long periods of time that sticky stuff has a tendency to unstick![]()
We just had to go through with gorilla glue & re-stick some of ours in the shitboxYeah I told my wife that but she didn’t listen. With my other camper I kept heat and condensation down by leaving the vent and a couple windows cracked so I’m hoping for the best
Buy some cheap buckets of moisture absorbent material, cannot recall the name but we keep two buckets in ours anytime its closed up. Made for this purpose.Yeah I told my wife that but she didn’t listen. With my other camper I kept heat and condensation down by leaving the vent and a couple windows cracked so I’m hoping for the best
I'm legitimately in awe at how much you've done in such a short amount of time... I'd be at this step and then stare at it for 6 months...
This is why I haven't touched mine.I'm legitimately in awe at how much you've done in such a short amount of time... I'd be at this step and then stare at it for 6 months...
Braggercoffee bar
I assume all bulbs replaced with LED
if you use a ratcheting crimper with stainless rings it wont require as much room as a copper crimp ring. Might make it easier on you.I had a leak in the bathroom when testing the water. It was due the fitting not being tight but it was dang near impossible to get myself in there with both hands, and manage to get them tight. Screw some camper plumbing!
And if that wasn’t good enough, I have a 90° fitting above a T fitting cracked in the PEX pipe under the kitchen sink. It’s in an awful spot, not gonna be fun to fix at all.
