I currently have a Kaufman trailer that I bought new from Kaufman in June 2020 and will probably have it a long time because of current trailer prices, and because of the modifications I've made to it (power tilt, flip up winch, expanded storage, 17.5 wheels/tires). I've actually had 3 Kaufmans, but... I looked at a LOT of different stuff before buying mine, including the 2 poorly built Kaufmans I owned previously. I nearly bought a Diamond C, but just could not justify the price difference. That was 2 years ago, and it's an even greater spread now. The only reason I have a Kaufman is because they were one of the better cheap trailers. Or maybe the cheapest of the mediocre trailers.
There's some knowledge nuggets in these threads:
Wondering if anyone on the board works for them? If so.....what capacity? Even better specifically the Lexington manufacturing plant? If it's not appropriate for public pm me please.
nc4x4.com
So, a couple of months ago, I need to order a couple of trailer axles. Just a couple of standard Dexter 7k axles. In the past, I have gotten axles from Kaufman Trailer. Great prices, in stock, and you can just drive over and pick them up and save shipping and time. Called, talked to them...
nc4x4.com
Cheapo Tow Rig project (specifically page 16)
Also, kind of off topic, but entertaining:
After owning mine for 6 months here is what I would do differently. What about you?
nc4x4.com
And if you read that^, then this will give you a good laugh:
Anybody got any tips? I want to build it as cheaply as possible, but I want it to be the best. @marty79 @UncleWillie
nc4x4.com
Diamond C, Load Trail, Corn Pro, MaxxD, and many others make a MUCH better trailer than Kaufman and the other low cost, high volume guys. The PJ and Big Texx trailers seem to be somewhere in the middle. Mass produced and not as heavily built as the top names, but still better built fit and finish and design, and more features than a Kaufman. But you know what...they all use the same axles/bearings/tires, and have enough steel to get the job done. The real difference is in the features and conveniences. I ended up with the Kaufman because I couldn't justify the extra price for things that didn't add to the functionality. If I were in your shoes, I'd be looking at a hydraulic full tilt with torsion axles, to get the deck height and loading angle as low as possible. So for your use case, I would not even consider a Kaufman. Their full tilt is a weird double frame design that makes it ~6" higher than the competitors. And their partial tilt is not powered.
Something like the PJ TS series would probably be ideal since you need the low height, but the wide deck and drive over fenders would still allow you to easily load vehicles when needed:
Then look no further than the 6" Channel Super-Wide Tilt Trailer (TS). Spacious and sturdy with an extra wide 102" tilt deck, the TS is constructed to safely and securely haul heavier cargo and equipment with its 7K torsion axles and forward self-adjusting brakes. And when dealing with large...
pjtrailers.com
Or a Load Trail or Diamond C if you're feeling frisky (getting full tilt may be build to order, but a partial tilt would work for your scissor lift and material needs):
TH14 – Available Sizes Standard Features Axles Available Colors Options *TH14 stock photo. May be shown with optional equipment. ‹›× ‹› Standard Features Axles: 2-7,000 Lb Cambered Dexter Torsion (UP) 2 Elec NEV-R-ADJUST Brakes Couplers: 2-5/16″ Adjustable Crossmembers 3″ Channel 16″ OC (3.5...
loadtrail.com
This intelligently crafted HDT low profile hydraulically dampened tilt bed trailer is ready to take on your world, one heavy load at a time.
www.diamondc.com
Also, you could probably get away with a gravity tilt, which would eliminate the issue of dead batteries. The only reason I converted mine to power tilt was to hold the tilt portion in a tilted position once heavy things (such as a lathe or long wheelbase vehicle) went past the tilt point. The nicer tilt trailers have a locking valve that would accomplish this, so you wouldn't even need power tilt and adjustable tilt speed. I have a partial tilt because my primary use is the skidsteer, and I am able to leave attachments on the stationary portion at the front, and get on and off the trailer without having to strap them down.
