Future shop build advice
Can any of you smart folks figure out what I need to use to clean out my sprayer with after I put this stuff down? I can't find anything. Water or acetone?
Mek would my choice, but acetone should work fine. Definitely not water
Bumping this up again. Interested in what others are seeing for cost now.
I had a 30x40 pole barn style building with 10x40 lean to down one side built around 2018. Almost immediately realized it wasn't big enough (I know it never will be) and have always talked about adding on to it. Got the guy that built it to quote removing the rear wall and adding 20-30 ft to it, including the lean to. He warned me when he came over to look at the grade etc before he got started on the quote that prices had went up significantly since COVID which I knew and have heard.
Got the quote today and was a bit of a sticker shock but wondering if the 3x materials prices that he is claiming is what everyone else in the market has seen.
He will be removing the rear wall and garage door (hopefully reusing the metal and purlins, can't reuse the 6x6 post that are in the ground i'd assume) and essentially just adding 20-30ft and reinstalling the rear wall and door.
He came in at 27,500 for 20ft and 36,500 for adding 30ft. Both quotes included concrete. The lean to doesn't have concrete so it's just a 20x30 or 30x30 concrete slab being added.
I think I only paid 32k for the building and concrete when I originally built it and it included concrete that went from the driveway to the shop, probably an additional 20ft. Am I wrong for struggling with a quote for an addition that cost more than the whole building was?
Seems exceptionally high to me, but I’m a cheapskate. The steel has gone up, maybe even doubled, but certainly not tripled. A quick check online shows galvalume at $3/foot. When I built mine in 2014 it was about $1.80/foot.
3x is actually pretty damn good
We just got the 2025 pricing books in. And even THEY are running low
Commercial buildings could be built in the $300 sqft range in 2023 but we're now topping the upper $500 sqft. So I can only imagine the pricing on something with absolutely NO margin like yours would be 4 or 5x. Hence why I say 3x sounds GOOD
Here are R&R Ironworks current sale prices.
That will give you an idea for materials package cost for standing roof or enclosed.
My 40x80 standing roof kit from R&R is supposed to be delivered tomorrow. So far I've got 3 quotes to install it. First guy was $5/sq.ft and second two were both $6/sq.ft Still waiting on 2 other people to get back to me.
Assuming Moss quoted it?
If so...he hit a homerun on a commercial project and now thinks he can price everything like that one job.
Unfortunately for him that homerun wasn't to true commercial standards and was 30% lower then competition prices so the way I see it, he is now stuck in a weird limbo. Where he's too cheap for commerical red iron work and too high for his long standing bread and butter resi garage work...
But yeah...I'd say he bumped his noggin
For a materials price comparison....I built this for my wife's school this year. It was a 20x30. Had around $7k ($2k trusses, $4k for the rest of framing, $1k for shingles) in it for just materials, concrete pad was $4k, and I put it up by the hour when I had time and had the high school carpentry class help roof it.......maybe i should have got them an R&R that was about twice this size 🤫
Also I didn't bury the post, just did 2x2 footer underneath post and anchored them in the concrete. Ive never done an R&R but I don't think I would do an open one without sleeving the post and burying them. This one sturdy but you can tell it's not the same as burying the post.
Roof looks great, but the rest of it looks questionable :flipoff2:
Ready for trusses tomorrow. Dude said he really likes the wetsets, esp since my concrete guys put them in the right spots.
Picked up a 36" old school Dayton exhaust fan with louvers and the motor off marketplace today for $150. No mad about it.
Where did you buy your wetsets? I looked at them online for the price I may make my own.
Home Depot online. I thought about making brackets but honestly, I don't have a break or a punch and it would have taken forever to cut, drill, and bend 19 brackets. Then if you do the ones with rebar you have to cut and weld all those on. When I weighed the cost, and the fact that the Simpson brackets have an actual rating sealed the deal. I still welded some rebar angles to my corner brackets just because I wanted them to have some more grab.
Need some help determining how far I can span with a free I-beam. Buddy has a 40ft w8x15 *maybe 18* but I couldn't get a great measure on the web thickness because of all the torch slag. I was planning to span 40ft with a post in the middle so 20ft clear. I'm thinking now I might need to third it and put 2 posts. This is for a loft in my shop. I could Google this more extensively, but that would take time and I know @jeepinmatt or one of you other smart folks will find it sooner.
Since you buzzards wouldn't bless me with your brilliance, I kept googling. Best I can tell, 15' span can support 10,xxx lb live load. My loft is 40x10 so using the 40psf live load number, the whole thing would only be 16,000lbs of potential load. The beam would be supporting only half that load (in my mind, correct me if I'm wrong) so I should be good with 2 posts equally spaced. I think I could cheat and go with 1 but I don't really know. There's no chance I'll have more than a few people up there even if I put a pool table up there one day.
Got most of my bathroom framed up yesterday.
Got to drink like a framer to think like a framer.
No self respecting wood butcher drinks Corona
Modelo FTMFW
Looking good BTW
That probably explains why I made the walls 3" too tall the first time and had to tear it back down and trim up the studs 🤣
Now you know why studs come in 93s...when you figure out the 92 5/8s tell me so we both know
Assuming that pad was 20x30, what was the thickness? Trying to figure out ahead of time whether it is worth pursuing doing my driveway this year.
I did the ceilings in my addition with 5/8" drywall and the 8' tall wallboards indeed hit about 1/2 off the floor with a single sill plate and a double top plate. 1.5+92.625+1.5+1.5=97.125. Then 97.125-96-0.625=0.5"
Write your reply...
